DDR4 example design仿真
- 5 years ago
Hi pp,
You actually doing it right.
After performing commands do msim_setup.tcl, you should perform the commands like below:
- dev_com
- com
- elab_debug
- add wave "ed_sim/*"
- transcript file transcript.txt
- run -all
I already share the run.do file at my first comment there.
It's contains the commands to simulate your design.
In order to use it,
- Copy the run.do into your msim_setup.tcl directory
- Open Modelsim
- Change directory to your msim_setup.tcl directory
- Perform do run.do in the transaction windows
Feel free to ask me when you still need some help.
Adzim
Hi pp,
Does the Modelsim shows any error in the transaction windows?
Or there is no reaction at all?
Can you confirm that the msim_setup.tcl is exists in your directory?
Which Quartus version that you used?
Have you tried to change the directory in the GUI?
You can change it by going to File>Change Directory...
Adzim
- pp5 years ago
Hi Adzim:
answer: please look at the picture,when i input command do msim_setup.tcl
answer : yes,i'm sure the msim_setup.tcl is exists my directory, please look at the picture
answer : yes, I used exactly the method you said
by the way, i'm using quartus 18.0 standard version
- AdzimZM_Altera5 years ago
Hi pp,
- dev_com
- com
- elab_debug
- run -all
In order to use it,
- Open Modelsim
Adzim
