DDR4 example design仿真
- 5 years ago
Hi pp,
You actually doing it right.
After performing commands do msim_setup.tcl, you should perform the commands like below:
- dev_com
- com
- elab_debug
- add wave "ed_sim/*"
- transcript file transcript.txt
- run -all
I already share the run.do file at my first comment there.
It's contains the commands to simulate your design.
In order to use it,
- Copy the run.do into your msim_setup.tcl directory
- Open Modelsim
- Change directory to your msim_setup.tcl directory
- Perform do run.do in the transaction windows
Feel free to ask me when you still need some help.
Adzim
Hi Adzim;
i will use english to repeat my question,i want to simulate the official DDR4 IP CORE,but i meet some problems。I will explain my steps to simulate DDR4 IP step by step. Please help me to see if there is any problem with my steps。
first: i open the modelsim and change directory,please look at the picture
second :I enter the following command in the modelsim command bar
third: I enter the following command in the modelsim command bar
And then there was no reaction,what should i do?
