DDR3 SDRAM Controler Compilation
Hello Adzim,
I think I finally found the reason, why it worked on the other pc and not on mine.
One difference was, that the windows user account on the other pc was a local one, called Admin.
So I additionally added to my domain account on my working pc, a local one called "ChrisLokal",
After that, it also worked on this pc.
To verify my assumption I additionally created a local account called "Christian Lokal", resulting in the known issue during compilation of the DDR3 controller.
So, my assumption is, that the problem is related to the space in the user account name between "Christian" and "Lokal". (There is also a space in my company domain account.)
Hopefully this information helps to reproduce the problem and pinpoint you to the cause of the issue.
Christian
