Elegan
5 years agoDDR3 SDRAM Controler Compilation
After updating to Quartus Prime Standard 20.1 compilation of the DDR3 SDRAM Controller IP fails. (Error log attached). I also tried to solve the issue by installing WSL as described in following c...
AdzimZM_Altera
5 years agoHi Christian,
Yes that what I mean.
Your computers might have the differences but that differences shouldn't cause the error.
And your computers have the same build internally.
By right it should be work normally as other computer.
I'm sorry for cannot help you to solve this.
But maybe you can continue your project in your other computer.
I'm hope you are fine with that.
Adzim
