DDR3 SDRAM Controler Compilation
Hi Christian,
Thanks for sharing the error log.
It does looked like still the same errors.
I guess you have to use the quartus in your other computer.
You already reinstalled everything in your main computer but still cannot solve the problem.
But your other computer can simply solve the error when applying the workaround.
Even both computers are same.
Or is there any difference between the computers?
But if you still want to use your main computer, maybe you can implement the quartus into the virtual machine(vm).
But I'm not guarantee it will work.
I hope that you understand about this.
Adzim
- Elegan5 years ago
Hi Adzim,
technically the computers are not the same. Mine is much older and of course has different hardware. But I don't see how this could impact the compilation process of the DDR3 controller. And if you don't see anything in the error log, I truly understand, that you are running out of ideas.
I just wanted to evaluate the improvements made to qspi flash support, as I think that it is not ideally implemented in Quartus 18.0, the version I am working with at the moment.
Nevertheless, thank you very much for your support.
Stay safe,
Christian
