Elegan
5 years agoDDR3 SDRAM Controler Compilation
After updating to Quartus Prime Standard 20.1 compilation of the DDR3 SDRAM Controller IP fails. (Error log attached). I also tried to solve the issue by installing WSL as described in following c...
AdzimZM_Altera
5 years agoHi Christian,
What is the windows build version in both of the pc?
I think you need to regenerate your project file if it's possible.
Can you try the workaround from this KDB:
Can I have the error logs after you reinstall the windows?
Adzim
- Elegan5 years ago
Hi Adzim,
the windows build version is 19043.1165.
I tried the workaround although it doesn't make much sense to me. As expected, it reported, that Windows Subsystem for Linux is needed.
I assume this workaround is for Quartus versions <19.1 where cygwin is used instead of WSL.
Please find the error log after the reinstallation of windows attached.
Christian
