DDR3 SDRAM Controler Compilation
Hi Christian,
I've found some steps that have been used by the engineer.
Hopefully it's work with you.
Can you test it?
- uninstalled Ubuntu 18.04
- uninstalled wsl
- re-installed wsl
- downloaded latest Ubuntu 18.04 from Microsoft Shop & installed it
- executed following on Ubuntu shell :
sudo apt-get update
sudo apt install wsl
sudo apt install dos2unix
sudo apt install make
sudo apt-get upgrade
Let me is this can help you.
Adzim
- Elegan5 years ago
Hi Adzim,
after reinstallation of the components in your suggested order, I am still not able to compile the DDR3 IP.
I also tried to uninstall everything (including Quartus) and install it in the order of WSL, Ubuntu, Quartus but still without success.
After that I did the same on another pc. On this computer the IP compilation was successful.
I really don't know whats the big difference between my working pc and the one, where compilation was successful. (Windows-Versions are almost the same)
Maybe I have to completely reinstall Windows to be successful on my working pc.
Christian
