DDR3 SDRAM Controler Compilation
Hi Christian,
Have you restart your computer after the installation process?
Do the error messages are prompting the same thing with your first one?
I have looked internally and found this from the engineer.
To debug this, ensure WSL is installed correctly on the Windows machine and you can test this by launching Nios2 Command Shell.
Done.
Next step, it would go to the IP owner to determine if they are invoking Nios2 Command Shell correctly.
In all scenarios, Qsys merely evaluates what's written in the IP's HWTCL file. If it fails when attempting to run something from the IP's HWTCL file, it is most likely something not working within that IP.
Can you identify it?
Adzim
- Elegan5 years ago
Hello Adzim,
just gave it another try.
1. Restarted Computer
2. To see if everything is correct launched Nios2 Command shell (see attached screenshot)
3. Picked DDR3 SDRAM Controller with UniPHY Intel FPGA IP from the IP Catalog
4. To keep it simple: Selected Elpida EDJ1108BASE-8C from the Presets tab.
5. Finish and generated it without Example Design
It resulted in exactly the same Error log.
Christian
