Elegan
5 years agoDDR3 SDRAM Controler Compilation
After updating to Quartus Prime Standard 20.1 compilation of the DDR3 SDRAM Controller IP fails. (Error log attached). I also tried to solve the issue by installing WSL as described in following c...
AdzimZM_Altera
5 years agoHi Christian,
It's good to hear that you are able to launch the Nios2 Command Shell.
Do you able to regenerate your IP now?
Adzim
- Elegan5 years ago
Hello Adzim,
no, unfortunately I'm still not able to regenerate the IP now.
Christian
