DDR3 SDRAM Controler Compilation
Hi Christian,
I'm Adzim. Thanks for using Intel Community.
I have reviewed you error logs and look like this is a known issue.
I have saw that you already tried to fix the issue by installing the WSL on your OS.
I believe that you already refer to this:
But the difference is that they have used the Ubuntu version 18.04 while you are using version 20.04.
I'm wondering is this can make a difference in solving your issue.
Would you able to use Ubuntu version 18.04 LST instead of 20.04?
After the installation has completed, can you launch the Nios2 Command Shell?
Adzim
- Elegan5 years ago
Hello Adzim,
yes, at my first attempt I installed 18.04, with the same result.
20.04 was my last attempt, following the instruction of the las post of following community case.
Nevertheless I just uninstalled 20.04 and reinstalled 18.04 and successfully launched the Nios2 Command Shell.
Christian
