14 years agoI'm not sure what could be happening to cause the ECC bits to not calibration since I have not used ECC before. One thing to check is whether the memory DIMM even has a 72-bit data bus. I could see memory module manufactures leaving the extra 8-bits out to save money in the DIMMs for PCs (i.e. not servers) since typically only server grade processors implement ECC. So calibration could be failing due to a lack of there being ECC memory present.
The easiest way to check this is count the number of SDRAM ICs on the module, if it has 8 or 16 then you only have a 64-bit data bus.
