14 years agoThanks for your response.
Reducing column width: Say I instantiate UniPHY DDR3 with a DIMM (like the Micron one that comes with Stratix IV E kit). And it's too large of a span, for reasons you mentioned. Can I keep everything exactly the same, with one exception: simply change the column bits from 10 to 8? (I did this, and all the errors listed above go away. Basically, I'm trying to reduce the usage of that DIMM by 4: only use the bottom 1/4th of the available columns). Is this okay, or will there be yet other issues by changing the column bits in instantiation from 10 to 8? Thanks, Aaron
