17 years agoIf you deleted the example driver but haven't replaced it with your own code yet, then the unconnected local bus side of the controller might be causing too much to synthesize away. If that's the case, it might be enough temporarily to connect the local bus side to top-level device pins (with virtual-pin assignments for them in the Assignment Editor if needed to keep from getting a no-fit from too many pins)
