17 years agoDDR SDRAM controller
Hi Where can find a complete example design which has sdram controller interfacing custom logic with avalon master...without using nios. Thanks in advance, usha.
Hi Jake,
Thanks for the reply. My requirement is follows… I have some custom logic (say an adder(16-bit)), and I should read data from ddr-sdram and write back to the ddr-sdram. My understanding is that the custom logic should have an Avalon mater interface to this. And this ip + ddr-sdram controller + pll to be used in sopc builder to generate the RTL. I failed to find an example to do this. Any sample example to do this will be of great help. usha
