12 years agoYou best use ALtera's ALTDDIO_OUT primitive; a 16-bit wide to drive the data and a 1-bit wide to drive the clock. Connect DataA to the datain_l port and DataB to the datain_h port of the 16-bit wide component. You connect "1" and "0" to the datain_h and datain_l of the 1-bit wide clock driver. So the clock to the DAC nicely arrives edge-aligned with the DDR data.
