8 years agoData dependency caused by conditional global memory read
Hi, When I compile my code, in the loop analysis of the generated report file there's one loop which has iteration interval of 4, which means it's not pipelined well.
for (uint loop...
8 years agoHi HRZ,
Thanks for your reply! Yes I had a typo there (that buffer is a data structure, it should be "data_double_buf[wr_bank_sel][cp][w].vector[v] = 0.0f;" Thanks for pointing out. Is there any pragma that can remove false local memory dependency like# pragma ivdep? (Not for this problem)
