8 years agoData dependency caused by conditional global memory read
Hi, When I compile my code, in the loop analysis of the generated report file there's one loop which has iteration interval of 4, which means it's not pipelined well.
for (uint loop...
8 years agoHi HRZ,
Thanks for your reply. The report means there are dependency between line "data_double_buf[wr_bank_sel][cp][w] = 0.0f;" and line "data_double_buf[wr_bank_sel][cp][w] = input[h * input_dim1 * input_dim2 + (y - pad_size) * input_dim1 + x - pad_size];" which belongs to two different conditional branches. Is it global memory dependency or local memory dependency?
