8 years agoData dependency caused by conditional global memory read
Hi, When I compile my code, in the loop analysis of the generated report file there's one loop which has iteration interval of 4, which means it's not pipelined well.
for (uint loop...
8 years agoWhich line is line 122 in your code? False dependencies on "global" buffers can be avoided by adding# pragma ivdep array(*buffer_name*) before the loop (Best practices guide, Section 5.2). Note that incorrect use of this pragma WILL result in incorrect output.
