13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
10 years ago --- Quote Start --- Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can somebody give me some suggestion on what I did wrong? http://www.alteraforum.com/forum/attachment.php?attachmentid=6876&stc=1 fyi: I create the data output to the board from 0-16300-0... (so that it will be a triangle waveform) I'm still doing and glad to here from you. Thank you, Tan --- Quote End --- I am sorry , i am very very new to DE2-115 , now i need to connect my DE2-115 to THDB-ADA_HSMC , same like yours . But can i know is there any extra coding needed in order to make the connection ? And also how do you assign the pin assignment for this ADA?
