13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoI used clockR/F to avoid clock skew. You can use:
ClockR<=Clock; ClockF<=not(Clock);
