13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoHi Roy,
I'm sorry for the dela as I was travelling for the holiday. What you need is exactly my code. The PLLs are the clock from FPGA board to the daughterboard. The WRT is, to be simple, to enable the write command to write to DAC Cheers, Tan
