13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoHi Dear Tan,
I just bought the THDB ADA to be use with DE2-115 board. for the 1st timer I tried to feed the device a function from function generator, and display it on an oscilloscope. I think I got all the pin assignment which I did acknowledge. But it seems that there's none function displayed on the output display. What am I missing in the code ? what do i do ? I think some of your line below wont be necessary for mine right ? --PLL_OUT_ADC(0) <= clockR; --PLL_OUT_ADC(1) <= clockR; --PLL_OUT_DAC(0) <= clockF; --PLL_OUT_DAC(1) <= clockF; --DAC_WRTA <= clockF; --DAC_WRTB <= clockF; What is that PLL_OUT_xxx & DAC_WRTA/B is for ? --------------------------------------------------------------------------------------------- Following is my code in VHDL LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY SIN IS PORT ( -- ADC / DAC --------------------- ADC_DB : IN STD_LOGIC_VECTOR(13 DOWNTO 0); DAC_DB : OUT STD_LOGIC_VECTOR(13 DOWNTO 0); -- Setup ADC and DAC ------------- DAC_MODE : out std_logic; -- DAC mode, 1 for dual --DAC_WRTA : out std_logic; -- Write signal Channel A --DAC_WRTB : out std_logic; -- Write signal Channel B ADC_OEA : out std_logic; -- Channel A enable ADC_OEB : out std_logic -- Channel b enable --PLL_OUT_ADC : out std_logic_vector(1 downto 0); --PLL_OUT_DAC : out std_logic_vector(1 downto 0) -- Clock from HSMC -- Clock ------------------------- --CLOCK_50 : IN std_logic ); END SIN; ARCHITECTURE dataflow OF SIN IS BEGIN --Clock processing--------------------------- --process(CLOCK_50) --begin -- if falling_edge(CLOCK_50) then -- clockF <= not(clockF); -- end if; -- if rising_edge(CLOCK_50) then -- clockR <= not(clockR); -- end if; --end process; --DAC and ADC interface---------------------- --PLL_OUT_ADC(0) <= clockR; --PLL_OUT_ADC(1) <= clockR; --PLL_OUT_DAC(0) <= clockF; --PLL_OUT_DAC(1) <= clockF; --DAC_WRTA <= clockF; --DAC_WRTB <= clockF; DAC_MODE <= '1'; -- Dual mode ADC_OEA <= '0'; ADC_OEB <= '0'; --Original Plan---------------------------- DAC_DB<=ADC_DB; END dataflow;
