13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoI've done the modification, but it is still the same result for the simulation.
And I can't display the iCLK_50, because it is impossible to define a signal as both clock signal and SignalTap signal ...
