13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoThanks for your quick answer !
I've changed the librairies, thank you, I did not know how to use them ^^ More over i've checked the pin assignement, it seems good.. This is my simulation, and below the setup. However I don't understand why clockF and clockR are in phase... https://www.alteraforum.com/forum/attachment.php?attachmentid=8720 And i've forgetten to say : I'va connected the DA-Channel B with the AD-Channel B by a SMA wire.
