13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoHi !
I'm currently working with DE2-70 and the daughter board THBD-ADA, but by a different way : I have to send a sinus wave (in digital) from the board to the DAC converter, then to the ADC converter, and get it back, to study this transmission. For being able to see the signals, i'm using SignalTap, but i don't know if my signals are sent or not received... I've already tried to use the code you've purposed, and adapt it, but it doesn't works.. This is my code : library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; -- WARP : use work.std_arith.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_signed.all; use ieee.numeric_std.all; ENTITY Coucou Is PORT( iCLK_50 : IN std_logic; -- Horloge de 50 MHz -- Entrees/Sorties DAC_DA, DAC_DB : OUT std_logic_vector(13 downto 0); -- D-A ADC_DA, ADC_DB : IN std_logic_vector(13 downto 0); -- A-D -- Setup ADC and DAC DAC_MODE : OUT std_logic; -- DAC mode, 1 for dual, 0 for interleaved DAC_WRTA : OUT std_logic; -- Write signal Channel A DAC_WRTB : OUT std_logic; -- Write signal Channel B ADC_OEA : OUT std_logic; -- Channel A enable ADC_OEB : OUT std_logic; -- Channel b enable PLL_OUT_ADC0, PLL_OUT_ADC1 : OUT std_logic; PLL_OUT_DAC0, PLL_OUT_DAC1 : OUT std_logic); -- Clock from GPIO END Coucou; ARCHITECTURE Archi_Coucou OF Coucou IS TYPE VAL_FUNCTION IS ARRAY (0 TO 49) OF INTEGER; -- tableau de 50 entiers SIGNAL Sinus : VAL_FUNCTION; SIGNAL a : INTEGER; SIGNAL clockF, clockR : std_logic; BEGIN --Create signal------------------------------ Sinus <= (0 => 0, 1 => 1027, 2 => 2037, 3 => 3016, 4 => 3947, 5 => 4815, 6 => 5608, 7 => 6312, 8 => 6917, 9 => 7412, 10 => 7791, 11 => 8047, 12 => 8176, 13 => 8176, 14 => 8047, -- 50 points per periode 15 => 7791, 16 => 7412, 17 => 6917, 18 => 6312, 19 => 5608, 20 => 4815, 21 => 3947, 22 => 3016, 23 => 2037, 24 => 1027, -- Frequency of 10 MHz 25 => 0, 26 => -1027, 27 => -2037, 28 => -3016, 29 => -3947, 30 => -4815, 31 => -5608, 32 => -6312, 33 => -6917, 34 => -7412, -- points calculated for 14-bit words 35 => -7791, 36 => -8047, 37 => -8176, 38 => -8176, 39 => -8047, 40 => -7791, 41 => -7412, 42 => -6917, 43 => -6312, 44 => -5608, 45 => -4815, 46 => -3947, 47 => -3016, 48 => -2037, 49 => -1027); --Clock processing--------------------------- process(iCLK_50) begin if falling_edge(iCLK_50) then clockF <= not(clockF); end if; if rising_edge(iCLK_50) then clockR <= not(clockR); end if; end process; --DAC and ADC interface---------------------- PLL_OUT_ADC0 <= clockR; PLL_OUT_ADC1 <= clockR; PLL_OUT_DAC0 <= clockF; PLL_OUT_DAC1 <= clockF; DAC_WRTA <= clockF; DAC_WRTB <= clockF; DAC_MODE <= '1'; -- Dual mode ADC_OEA <= '0'; ADC_OEB <= '1'; -- Outputs create_signal_process: process(clockR) VARIABLE CLK_Count : INTEGER :=0; begin if rising_edge(clockR) then IF (CLK_Count < 50) THEN a <= Sinus (CLK_Count); DAC_DB <= std_logic_vector(to_signed(a, 14)); -- Convert sinus into 14-bit word CLK_Count := CLK_Count + 1; ELSE CLK_Count := 0; END IF; end if; end process; END Archi_Coucou; Does somebody can help me ? Thanks and scuse me for my approximative english ...
