13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoHi tan,
I am currently creating a spread-sheet for the pin assignments. Well thanks a lot! i'll verify my assignments with what you have sent. I have another doubt, The ADA board feature list mentions the following: The feature set of the ADA is listed below: 1. Dual AD channels with 14-bit resolution and data rate up to 65 MSPS 2. Dual DA channels with 14-bit resolution and data rate up to 125 MSPS 3. Dual interfaces include HSMC and GPIO, which are fully compatible with Cyclone III Starter Kit and DE1/DE2/DE2_70/DE2_115/DE3/DE4, respectively 4. Clock sources include oscillator 100MHz, SMA for AD and DA each, and PLL from either HSMC or GPIO interface 5. AD converter analog input range 2V p-p range. 6. DA converter output voltage range 2V p-p range. 7. DA and AD converters do not support DC signaling The entire board operates on DC-signaling if am not wrong, as our board is powered by an adapter. So what does it exactly mean by DA and AD converters do not support DC signalling? Also i think there is a mistake in the pins wrt_a and wrt_b as there is no pin such as T24 and W25 available. Am attaching the schematics of Cyclone 3 Starter Board for your reference. thanks! ivads
