13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoPins assignment for Cyclone 3 Starter Board
Assign this and try my code above ADC_OEA Location PIN_T3 ADC_OEB Location PIN_R3 CLOCK_50 Location PIN_B9 DAC_MODE Location PIN_L1 DAC_WRTA Location PIN_T24 DAC_WRTB Location PIN_W25 PLL_OUT_ADC[0] Location PIN_V18 PLL_OUT_ADC[1] Location PIN_U18 PLL_OUT_DAC[0] Location PIN_C14 PLL_OUT_DAC[1] Location PIN_D14 RESET Location ==> Choose one of your switch XIN[0] Location PIN_N13 XIN[1] Location PIN_M13 XIN[2] Location PIN_N6 XIN[3] Location PIN_M6 XIN[4] Location PIN_R18 XIN[5] Location PIN_R17 XIN[6] Location PIN_M14 XIN[7] Location PIN_L13 XIN[8] Location PIN_M17 XIN[9] Location PIN_L16 XIN[10] Location PIN_L18 XIN[11] Location PIN_K18 XIN[12] Location PIN_G18 XIN[13] Location PIN_G17 XOUT[0] Location PIN_T1 XOUT[1] Location PIN_N7 XOUT[2] Location PIN_N8 XOUT[3] Location PIN_J13 XOUT[4] Location PIN_N10 XOUT[5] Location PIN_N11 XOUT[6] Location PIN_K17 XOUT[7] Location PIN_P11 XOUT[8] Location PIN_B2 XOUT[9] Location PIN_B1 XOUT[10] Location PIN_G2 XOUT[11] Location PIN_G1 XOUT[12] Location PIN_K2 XOUT[13] Location PIN_K1 YIN[0] Location PIN_T18 YIN[1] Location PIN_T17 YIN[2] Location PIN_R4 YIN[3] Location PIN_R5 YIN[4] Location PIN_P18 YIN[5] Location PIN_P17 YIN[6] Location PIN_L15 YIN[7] Location PIN_L14 YIN[8] Location PIN_M18 YIN[9] Location PIN_L17 YIN[10] Location PIN_H18 YIN[11] Location PIN_H17 YIN[12] Location PIN_E18 YIN[13] Location PIN_E17 YOUT[0] Location PIN_M3 YOUT[1] Location PIN_T2 YOUT[2] Location PIN_H15 YOUT[3] Location PIN_H16 YOUT[4] Location PIN_N16 YOUT[5] Location PIN_N15 YOUT[6] Location PIN_R16 YOUT[7] Location PIN_T16 YOUT[8] Location PIN_C2 YOUT[9] Location PIN_C1 YOUT[10] Location PIN_H2 YOUT[11] Location PIN_H1 YOUT[12] Location PIN_K5 YOUT[13] Location PIN_L5
