13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years ago --- Quote Start --- I don't have a Cyclone 3 board here. I'm not sure what is your interface between the FPGA board and the daughter board. Is it HSMC or GPIO? Can you upload the pictures or give me the web links of your boards? First, use the FPGA board manual to obtain the pins for your interface. Make sure you can make a correct pins assignment. Second, try the program I wrote above. --- Quote End --- Hi duytan , Ya sure , I am attaching the pics of the ADA borad . It is the HSMC board , the first one in the attached pdf. And ya, i'll refer to the pins and keep the assignments ready. Will you be able to verify them for me? Cyclone 3 Starter board link is here. http://www.altera.com/products/devkits/altera/kit-cyc3-starter.html Thanks !
