13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
12 years agoI don't have a Cyclone 3 board here. I'm not sure what is your interface between the FPGA board and the daughter board. Is it HSMC or GPIO? Can you upload the pictures or give me the web links of your boards?
First, use the FPGA board manual to obtain the pins for your interface. Make sure you can make a correct pins assignment. Second, try the program I wrote above.
