13 years agoDAC with THDB-ADA on DE2-115
Hi there, I'm working with DAC on the daughter board THDB-ADA. The pin assignments are correct, I believe, but the circuit doesn't seem to be working. Here are my waveforms from ModelSim, can so...
13 years ago --- Quote Start --- I tried to test the program. However it doesnt work. I am using the altera DE2 board and the terasic daughter board. I checked the pin assignment. I cant see anything in the output. Could you help me with this??? --- Quote End --- Could you tell me how you set up your design? If I will check the basic operation, I would set it like: Use an SMA cable to connect the ADC channel A to a generator, say you're using a 1V, 500kHz sine wave. Use another SMA cable for the DAC channel A to the osciloscope. Make sure the contact between your THDB ADA to your DE2-115 is HSMC and is firm (pushing it down a bit hard) If it doesn't work either, check the jumpers on your daughter board. Leave it as default if you've changed something. I'm curently not with my board so I can't check it. If it doesn't work either, connect the data, XIN, to the LEDS to check if it works. If not, make sure to set the ADC_OEA to 0
