11 years agoCyclone V PR with Internal Host
Hi, I am using the Cyclone V SoC (5SCEMA5F31C6N) and I want to set up a simple Partial Reconfiguration Project. I'm getting an error when trying to configure an internal host using the megawiz...
11 years ago --- Quote Start --- PR is supported with internal and external host as explain from the user guide. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/megafunctions/ug-partrecon.pdf Make sure you are using the lastest Quartus II version that support this IP with Cyclone V. --- Quote End --- The user guide refers to the Stratix V device family (see first paragraph). I am using a Cyclone V board which has a reduced feature set compared to Stratix. Is it still possible to use an internal host?
