11 years agoCyclone V GX transceiver simulation model needs Arria V modules?
Using Quartus II v15.0, and ModelSim Starter 10.3d. I am working on a new design, targeting a Cyclone V GX device. Before digging into the whole design, I generated a Cyclone V Transceiver Nati...
11 years agoI believe some of the Cyclone V simulation models have been shared with Arria V models since both of them are generation V devices. However, it is unusual to get into the missing models error. Mind sharing on how do you compile the libraries? By default, there would be a file with name which sounds like msim_setup.tcl after you generate the PHY. Inside the tcl, you will find the required sequence to compile simulation model libraries.
