alan_r
4 years agoCyclone iv - triple speed ethernet set to RGMII
I’m looking for an example of a Cyclone IV (Quartus Prime Standard & Platform Designer) using “triple speed ethernet” in RGMII mode.
Concerns: output: tx_clk input: rec_clk
--Alan
paveetirrasrie_Altera
4 years agoHi Alan Jayson,
Below picture attached shows variations for TSE Ethernet Cyclone IV devices. For RGMII setting, IP variation is 1000 Mbps Small MAC. By using the applicable, you will be able to generate design example for TSE.
Here's the link for TSE UG. You can refer more detail on how to generate design example on TSE UG.
https://www.intel.com/content/www/us/en/docs/programmable/683402/22-1-20-0-0/about-this-ip.html
Pavee
- alan_r4 years ago
Hi Pavee,
The attached picture is not attached.
--Alan
