8 years agoCyclone 10 LP sof2flash unrecognized device family
Hello, I am trying to generate programming files for a Cyclone 10 LP device using the sof2flash tool of the Nios EDS in Quartus Prime 17.1.1.593: sof2flash --input="abc.sof" --output="abc....
8 years ago --- Quote Start --- Did you solve the problem? I met the same situation --- Quote End --- I could not find a solution to the problem so I changed my programming file generation. I am now using the "Convert Programming Files..." tool from quartus to generate a .jic file from the .sof and the .hex file that can be generated with the mem_init_generate build target of NiosII SBT. See AN-736 from Altera for details.
