nasalmirror
5 years agoCyclone 10 fails to program jic on MT25QU128 memory
As the suject states, my cyclone 10 10CL010Z256IG fails miserably to program jic on the attached memory, which is a MT25QU128. The hardware is all configured properly, with all pins connected how the...
YuanLi_S_Intel
5 years agoHi,
Yes, probably you can try with that. Hardware, JTAG should be problem as SOF can be programmed. Potential issue is the MSEL setting, configuration scheme selected in Quartus, Memory Device and etc.
Also, may I know what is the full micron OPN that you used in the design. The tested micron OPN can be found here.
Bruce
