nasalmirror
5 years agoCyclone 10 fails to program jic on MT25QU128 memory
As the suject states, my cyclone 10 10CL010Z256IG fails miserably to program jic on the attached memory, which is a MT25QU128. The hardware is all configured properly, with all pins connected how the...
YuanLi_S_Intel
5 years agoThanks. Instead of attaching the JIC file. Can you try to click detect, then only attach the JIC on the cyclone 10 and try to program?
nasalmirror
5 years agoIt does not work either way. The thing is, when I do autodetect it finds only my FPGA, but I can attach a flash device manually. I select MT25QU128, and even without any programming file selected, if I for example try doing BLANK CHECK it gives me the same ID error. I bought a new memory module in hope that the new one will work.
