nasalmirror
5 years agoCyclone 10 fails to program jic on MT25QU128 memory
As the suject states, my cyclone 10 10CL010Z256IG fails miserably to program jic on the attached memory, which is a MT25QU128. The hardware is all configured properly, with all pins connected how the...
YuanLi_S_Intel
5 years agoHi,
I think the memory model that comes in Quartus during programming file generation should be fine.
What you mean by CS timing? Are you referring to CS0 pin?
The potential fix for this error message can be found in link below, please try:
Moreover, can you screenshot me the setup in Quartus Programmer when you are programming JIC?
Bruce
- nasalmirror5 years ago
Here is the screenshot requested.
The link you sent me suggests good solutions but I checked everything and all is set properly.
