nasalmirror
5 years agoCyclone 10 fails to program jic on MT25QU128 memory
As the suject states, my cyclone 10 10CL010Z256IG fails miserably to program jic on the attached memory, which is a MT25QU128. The hardware is all configured properly, with all pins connected how the...
YuanLi_S_Intel
5 years agoYou may refer to guide below to change TCK frequency on USB Blaster, i would suggest to try with 16M / 6MHz.
Meanwhile, check you MSEL and see if it is set to active serial mode or not.
- nasalmirror5 years ago
I already tried doing that, but my USB BLASTER is not the Second version, and the JTAG jtagconfig --setparam <cable number> JtagClock <frequency> doesn't work. It says that JtagClock is an invalid parameter.
I would also like to know how to adjust the CS timings in a custom memory model (from quartus programming file converter), and then pass it to the jic file.
