12 years agoCustomPHY Megafunction generates different ports in component and implementation
I am having a problem with using the Custom Transceiver PHY in a simple design. When I create the PHY using the Megafunction Wizard (default options for everything), it creates the implemntation VHDL file with the following entity declaration:entity customphy_v13 is
port (
phy_mgmt_clk : in std_logic := '0'; -- phy_mgmt_clk.clk
phy_mgmt_clk_reset : in std_logic := '0'; -- phy_mgmt_clk_reset.reset
phy_mgmt_address : in std_logic_vector(8 downto 0) := (others => '0'); -- phy_mgmt.address
phy_mgmt_read : in std_logic := '0'; -- .read
phy_mgmt_readdata : out std_logic_vector(31 downto 0); -- .readdata
phy_mgmt_waitrequest : out std_logic; -- .waitrequest
phy_mgmt_write : in std_logic := '0'; -- .write
phy_mgmt_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
tx_ready : out std_logic; -- tx_ready.export
rx_ready : out std_logic; -- rx_ready.export
pll_ref_clk : in std_logic_vector(0 downto 0) := (others => '0'); -- pll_ref_clk.clk
tx_serial_data : out std_logic_vector(0 downto 0); -- tx_serial_data.export
pll_locked : out std_logic_vector(0 downto 0); -- pll_locked.export
rx_serial_data : in std_logic_vector(0 downto 0) := (others => '0'); -- rx_serial_data.export
tx_clkout : out std_logic_vector(0 downto 0); -- tx_clkout.export
rx_clkout : out std_logic_vector(0 downto 0); -- rx_clkout.export
tx_parallel_data : in std_logic_vector(7 downto 0) := (others => '0'); -- tx_parallel_data.export
rx_parallel_data : out std_logic_vector(7 downto 0); -- rx_parallel_data.export
reconfig_from_xcvr : out std_logic_vector(91 downto 0); -- reconfig_from_xcvr.reconfig_from_xcvr
reconfig_to_xcvr : in std_logic_vector(139 downto 0) := (others => '0') -- reconfig_to_xcvr.reconfig_to_xcvr
end entity customphy_v13; However when I add the block to a block design and create an VHDL file from it, the component delaration in it is as follows COMPONENT customphy_v13
PORT(phy_mgmt_clk : IN STD_LOGIC;
phy_mgmt_clk_reset : IN STD_LOGIC;
phy_mgmt_read : IN STD_LOGIC;
phy_mgmt_write : IN STD_LOGIC;
pll_ref_clk : IN STD_LOGIC;
rx_serial_data : IN STD_LOGIC;
phy_mgmt_address : IN STD_LOGIC_VECTOR(8 DOWNTO 0);
phy_mgmt_writedata : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
reconfig_to_xcvr : IN STD_LOGIC_VECTOR(139 DOWNTO 0);
tx_parallel_data : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
phy_mgmt_waitrequest : OUT STD_LOGIC;
tx_ready : OUT STD_LOGIC;
rx_ready : OUT STD_LOGIC;
tx_serial_data : OUT STD_LOGIC;
pll_locked : OUT STD_LOGIC;
tx_clkout : OUT STD_LOGIC;
rx_clkout : OUT STD_LOGIC;
phy_mgmt_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
reconfig_from_xcvr : OUT STD_LOGIC_VECTOR(91 DOWNTO 0);
rx_parallel_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
Note that some of the ports are of different types. For example the pll_locked port is of type std_logic_vector(0 downto 0) inside the implementation, but of type std_logic inside the component declaration. ModelSim complains about type mismatch when I run my testbench. Any suggestions why it does this, and how to fix it? I am using Quartus II 13.0 64bit.
