9 years agocustomized component got overwriten
Hi, I have a customized AVMM slave device. I added the component in the QSYS. Everything works. However, every time after I make any changes to the source code of the component. If I comp...
9 years agoI don't understand. Your source code file (.v or .vhd) is getting overwritten and reverted back to a prior state? Do you mean the _hw.tcl file is getting overwritten?
In any case, if you make changes to a custom component's source code, it's a good idea to go back into the Component Editor (right click the component in the IP Catalog and select Edit), re-analyze the design on the Files tab, and click OK to recreate the _hw.tcl file. I think some more detail about exactly what is wrong is required here.
