8 years agoCustom QSYS component do not instantiate generic parameter correctly.
Hello I created a custom qsys component with generic parameters (baud rate of a UART for example). If I add my component to a NIOS configuration I can change the parameters of my component pr...
8 years agoYes the parameter does appear in the Parameters tab of the Component Editor.
I created the parameters with the Component Editor and generated the main frame HLD file with the Component Editor (Create Synthesis Files in the Files tab of the Editor). Editing the component shows the parameter in the Component Editor correctly.
