8 years agoCustom QSYS component do not instantiate generic parameter correctly.
Hello I created a custom qsys component with generic parameters (baud rate of a UART for example). If I add my component to a NIOS configuration I can change the parameters of my component pr...
8 years agoDoes the parameter appear in the Parameters tab of the Component Editor when you are creating the component? You have to have first read in the HDL code on the Files tab.
