8 years agoCSI-2 transmitter
Does anyone have a project with a CSI-2 transmitter?
For example, on 10M50 eval board. Because no matter how hard we try, mistakes always occur: Error: Pin "TX_HS_CP" requires a pseudo-differential I/O assignment. or Error: Can't place node "TX_HS_CP" -- node is a differential I/O node or Error: Can't place differential I/O pins and/or associated SERDES transmitters or receivers -- location assignments are illegal Error: Pin "TX_HS_CP" with Differential 1.8-V HSTL Class I I/O standard must be driven by the external clock output of an enhanced PLL Need helpNo RepliesBe the first to reply
