14 years agoCreating Clock Constraint w/ negative Phase
I'm working on a design converting from Xilinx to Altera. The following constrain is being used in the Xilinx UCF file. NET "clk_250_n_bufg" TNM_NET = "clk_250_n" ; TIMESPEC "TS_clk_250_n" = PERIOD "clk_250_n" TS_clk_125 / 2 PHASE - 2 ns HIGH 50 %; Can you use a negative rising and falling waveform edge, when creating a clock in TimeQuest? Thanks!
