10 years agoCreating a Versioned Repository for VHDL Files
Greetings All: Continually I create VHDL FPGA projects as required. In the projects, I create several .vhd files, some are specific for that project, some can be used in pretty much any proj...
10 years ago --- Quote Start --- Greetings All: Continually I create VHDL FPGA projects as required. In the projects, I create several .vhd files, some are specific for that project, some can be used in pretty much any project later, however sometimes they get some modification. For instance, I created a clock_generator.vhd for dividing the main clock to produce a slower clock. That has been used in many other projects. Of course in some projects, the simple clock divider wasn't exactly what I needed, so modified it. I added 'clock enable' ports in and out, changed generics from 'divide_by' to 'clock_in_rate' and 'clock_out_rate' using 'real' type, and a few other things as time progressed. Now if I start another project, with more than 1 version available it gets difficult to find/copy/paste the file into another project. Bug-fixing is not applicable to other copies as well. At one time I received an interesting suggestion... http://www.alteraforum.com/forum/showthread.php?t=48216&highlight=#4 I completely agree with the suggestion, it sounds way better than the 'trying-to-find-the-best-most-up-to-date-clock_generate.vhd-file' I'm doing currently. And the 'versioned' part is required because if I have to recompile an old project that uses the first version, it may not be that compatible with the '47th' version I have now. So it still needs to be referenced to that particular reversion file (unless purposefully updating that as well). Is there any information on file organization, I haven't heard any reference to that regarding to VHDL. David K. --- Quote End --- Download svn(Tortoise svn). It is industry's de facto version control software. It is free but meant for servers.You can also use it on your pc without server.
