In Vhdl there are not these problems....you can try to create a project_top.vhdl in which you istanziate other sub-modules....mux,decoder,registers...for your custom design....every module can be istanziated many times...even if it has the same name declared in its sub_module.vhdl file
For example...
Project-top.vhdl
Reg.vhdl
Dec.vhdl
Mux.vhdl
In Project-top.vhdl you can istanziate Reg.vhdl, for example, there Times
Component Reg
Port();
End component;
Component Dec
Port();
End component;
Component Mux
Port();
End component;
Inst1: Reg
Port map();
Inst2: Reg
Port map();
Inst3: Reg
Port map();
Inst4: Dec
Port map();
Inst5: Mux
Port map();
So...their names Are not important to define...you can use every module you design..eveywhere...
