15 years agoCrash in Quartus II 10.0
I am experiencing a crash every time I try to compile my code.
Back trace: Internal Error: Sub-system: OPT, File: /quartus/synth/opt/opt_op_mux.cpp, Line: 1394 cdb_is_connected(iterm) Stack Trace: 0x10c5c2: RTL_OPERATOR::mux_has_uniform_data + 0xe2 (SYNTH_OPT) 0x1137a8: RTL_OPERATOR::minimize_and_merge_mostly_muxes + 0x228 (SYNTH_OPT) 0x113f09: RTL_OPERATOR::family_aware_crack_muxes + 0x99 (SYNTH_OPT) 0x47d2e: RTL_OPERATOR::exit_process_muxes + 0xae (SYNTH_OPT) 0x47f84: RTL_OPERATOR::exit_cleaning + 0x124 (SYNTH_OPT) 0x15c70d: RTL_SCRIPT::call_common_rtl_fns + 0x4fd (SYNTH_OPT) 0x15e46f: RTL_SCRIPT::call_named_function + 0x41f (SYNTH_OPT) 0x15a57e: RTL_SCRIPT::process_script + 0x4ee (SYNTH_OPT) 0x2aa5: opt_process_netlist_scripted + 0x645 (SYNTH_OPT) 0x33a7: RTL_ROOT::process_sgate_netlist + 0x4c7 (SYNTH_OPT) 0xeee93: SGN_SYNTHESIS::high_level_synthesis + 0x153 (synth_sgn) 0xeffb5: SGN_SYNTHESIS::process_current_stage + 0x265 (synth_sgn) 0x7c924: SGN_EXTRACTOR::synthesize_partition + 0x104 (synth_sgn) 0x7e8c0: SGN_EXTRACTOR::synthesis + 0x150 (synth_sgn) 0x7efc3: SGN_EXTRACTOR::synthesis_and_post_processing + 0x83 (synth_sgn) 0xc561: sgn_qic_full + 0x1e1 (synth_sgn) 0x321c: qsyn_execute_sgn + 0xac (quartus_map) 0x1981b: QSYN_FRAMEWORK::execute_core + 0x8b (quartus_map) 0x1c271: QSYN_FRAMEWORK::execute + 0xc1 (quartus_map) 0xd9f1: qexe_get_tcl_sub_option + 0x981 (comp_qexe) 0x10326: qexe_process_cmdline_arguments + 0x416 (comp_qexe) 0x10424: qexe_standard_main + 0x84 (comp_qexe) 0x1753e: qsyn_main + 0x5e (quartus_map) 0x1c91: msg_main_thread + 0x11 (CCL_MSG) 0x1a08: _thr_final_wrapper + 0x8 (ccl_thr) 0x1c05: msg_thread_wrapper + 0x85 (CCL_MSG) 0x8db6: mem_thread_wrapper + 0x34 (ccl_mem) 0x2e373: msg_exe_main + 0x63 (CCL_MSG) 0x1892c: _main + 0x1c (quartus_map) 0x1ee39: __alloca_probe + 0x189 (quartus_map) 0x16fe6: RegisterWaitForInputIdle + 0x48 (kernel32) End-trace Any suggestions about what I should do?
