Agdepusen
5 years agoCrash: EMIF_TERMINATION_LOSS_DEVICE_60
Running 16.1 @ Windows 10 for an Arria 10 device (Reflex SOM module).
Quartus consistently fails with the following message:
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_mic...
CheepinC_altera
5 years agoHi,
Thanks for your update. For your information, the error triggerred is a Quartus internal error. I do not have visibility into the reason behind to this error. We will need to engage Engineering to understand further. However, since the Quartus version used is old, Engineering will recommend to upgrade to latest Quartus to check if it has been fixed.
If you are unable to try with latest Quartus, you can look into using the workaround of running in Linux since it is working for you. Sorry for the inconvenience.
Chee Pin
