Agdepusen
5 years agoCrash: EMIF_TERMINATION_LOSS_DEVICE_60
Running 16.1 @ Windows 10 for an Arria 10 device (Reflex SOM module).
Quartus consistently fails with the following message:
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_mic...
AdzimZM_Altera
5 years agoHi Sir,
Which IP that you used in your design?
When do the error appear?
- Agdepusen5 years ago
it started out as a full project with JESD204 and HPS.
The error is present in windows and not in linux
Removed the HPS components and the error is still present.
The last few lines:
Warning (19016): Clock multiplexers are found and protected
Warning (19017): Found clock multiplexer eth1_tx_clk
Warning (19017): Found clock multiplexer eth1_tx_clk~0
Warning (19017): Found clock multiplexer eth2_tx_clk
Warning (19017): Found clock multiplexer eth2_tx_clk~0
Info (13014): Ignored 17 buffer(s)
Info (13016): Ignored 17 CARRY_SUM buffer(s)CRASH.
This happens early in the analysis and synthesis part
