Agdepusen
5 years agoCrash: EMIF_TERMINATION_LOSS_DEVICE_60
Running 16.1 @ Windows 10 for an Arria 10 device (Reflex SOM module).
Quartus consistently fails with the following message:
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_mic...
AdzimZM_Altera
5 years agoHi,
Regarding to your problem with the Quartus v16.1 in windows environment, can you show me your error log or error messages in more detail so that I can get better understanding on the problem.
What IP that your are used?
May I know why you want to use the Quartus in Windows version? is the Linux version is not your?
- Agdepusen5 years ago
I'm a hardware developer and my tools primarily run on windows. I hardly ever touch quartus these days. but I used to do a lot of HDL development back in the days.
Now, the sole purpose for me to run quartus is that we need to setup signal tap for JESD debugging. And the HDL leads are away on vacation.
Here is the log :
Problem Details
Error:
Internal Error: Sub-system: SIN, File: /quartus/tsm/sin/sin_micro_tnodes_dag.cpp, Line: 516Invalid branch: EMIF_TERMINATION_LOSS_DEVICE_60Stack Trace:0x56939: SIN_DAG_INTERNAL_NODE::get_data + 0x1d9 (TSM_SIN)0x2508: EMIFTCL_BODY::get_parameter + 0x18 (TSM_EMIFTCL_CORE)0x5a67: emiftcl_taf_emiftcl_get_parameter_value + 0x227 (tsm_emiftcl_taf)0x14410: TclInvokeStringCommand + 0xf0 (tcl86)0x161e2: TclNRRunCallbacks + 0x62 (tcl86)0x17a65: TclEvalEx + 0xa65 (tcl86)0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)0xa5646: Tcl_EvalFile + 0x36 (tcl86)0xaf540: sta_read_sdc_file + 0x11c (TSM_STA)0xaf3e5: sta_read_default_sdc_files + 0x79 (TSM_STA)0xaf2cd: sta_read_sdc + 0x209 (TSM_STA)0x14410: TclInvokeStringCommand + 0xf0 (tcl86)0x161e2: TclNRRunCallbacks + 0x62 (tcl86)0x17a65: TclEvalEx + 0xa65 (tcl86)0x16ff7: Tcl_EvalEx + 0x27 (tcl86)0xa3bd: SSC_UTIL::tcl_eval + 0x2d (TSM_SSC)0x7e6c: SSC_UTIL::read_sdc_to_sta + 0xdc (TSM_SSC)0x7c9c: SSC_UTIL::read_and_apply_sdc_constraints + 0x10c (TSM_SSC)0x4a88: SSC_UTIL::build_tdb_sub_and_merge + 0x3c8 (TSM_SSC)0x43023: sutil_ssc_initialize_tdb_netlist + 0x33f (SYNTH_SUTIL)0x427b6: SUTIL_SSC::initialize_ssc + 0x7a (SYNTH_SUTIL)0x42851: SUTIL_SSC::SUTIL_SSC + 0x51 (SYNTH_SUTIL)0x2871f: sutil_ssc_build_comp_reg_info + 0x173 (SYNTH_SUTIL)0x1e537: MLS_NETLIST::remove_duplicate_dffs + 0x2e7 (SYNTH_MLS)0x17e7c: MLS_NETLIST::call_named_function + 0x1b0c (SYNTH_MLS)0x31cbd: MLS_INTERFACE::call_named_function + 0x6d (SYNTH_MLS)0x3c83e: RTL_SCRIPT::call_named_function + 0xe9e (SYNTH_OPT)0x40240: RTL_SCRIPT::process_script + 0x4f4 (SYNTH_OPT)0x41169: opt_process_netlist_scripted + 0x7a5 (SYNTH_OPT)0x39f0a: RTL_ROOT::process_sgate_netlist + 0x196 (SYNTH_OPT)0x15801d: SGN_SYNTHESIS::high_level_synthesis + 0x17d (synth_sgn)0x1589dd: SGN_SYNTHESIS::process_current_stage + 0x20d (synth_sgn)0xc3a7d: SGN_EXTRACTOR::synthesize_partition + 0x18d (synth_sgn)0xc367f: SGN_EXTRACTOR::synthesis + 0x1ff (synth_sgn)0xc37e4: SGN_EXTRACTOR::synthesis_and_post_processing + 0xc4 (synth_sgn)0x131a0: sgn_qic_full + 0x2a0 (synth_sgn)0x4391: qsyn_execute_sgn + 0x131 (quartus_map)0x13fac: QSYN_FRAMEWORK::execute_core + 0x12c (quartus_map)0x13ab6: QSYN_FRAMEWORK::execute + 0x496 (quartus_map)0x112bc: qexe_do_normal + 0x1ec (comp_qexe)0x16142: qexe_run + 0x432 (comp_qexe)0x16e51: qexe_standard_main + 0xc1 (comp_qexe)0x1b06b: qsyn_main + 0x51b (quartus_map)0x13328: msg_main_thread + 0x18 (CCL_MSG)0x14b0e: msg_thread_wrapper + 0x6e (CCL_MSG)0x15b00: mem_thread_wrapper + 0x70 (ccl_mem)0x12a11: msg_exe_main + 0xa1 (CCL_MSG)0x29862: __tmainCRTStartup + 0x10e (quartus_map)0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)0x52650: RtlUserThreadStart + 0x20 (ntdll)End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 16.1.2
Build: 203
Edition: Standard Edition
